I have this Nokia C020 which I am assured is a Wifi card even though it will only work with Windows 98.
Does anyone know how to configure it to connect to a network. There are only cryptic connection possibilities such as and none of them SEEM TO let you scan, see available or select a network. I know that the card is working as it does install and shows a haywire screen on a nearby computer to which it is trying to connect peer to peer. It has three operating modes, instanet, StructureNet and peer to peer, none of which let me select or join a network. Does anyone know what is going on please?
Also, not that I think this can be relevant, but this computer shows Windows
95 on it but has something called Windows 98 PLUS installed, whatever that is, Anyway I have updated it to current patches along with IE6
