Hello, I need to install WIFI to work along with my LAN. The LAN bases on a huge switch with one WAN RJ-45 cable and many LAN cables from all around the office. The swich is in the corner of the office so I would like to attach WIFI somewhere else, so the range would be good enough in the other end of the office as well. Is the usual WIFI with 4 LAN ports and 1 WAN port a good device for it? Like i.e. D-Link DI-524? And how do I install it? I imagine I must connect the WAN port in WIFI router to any LAN port in my office somewhere on the wall. Is that correct? If not how should I do this? And also which company do you suggest for the best range and smallest amount of problems? Is the WIFI n - standard RangeBooster sth worth investing? Thanks in advance!
- posted
15 years ago
