You don't. The most likely result is fire and smoke. Most routers include a voltage regulator that will try absorb any over voltage on the DC input line. When it exceeds some voltage or dissipation level, the regulator will blow up. A wireless router is not a CB radio. I suggest you tinker with the antennas instead. The results tend to be less destructive and create less e-waste scrap.
