Hi all,
Got a 54G wireless network. Is there any software or a way in Windows that will tell me if I have someone "piggybacking" onto my Network?
Cheers,
Karl.
Hi all,
Cheers,
Karl.
If nothing else, your AP/router/whatever should have some way to display the MAC addresses of all the systems that are connected.
That's only if he doesn't want them in.
He just asked if there was a way to see.
There are intrussion detection systems for Windows and wireless networks. But these programs are for professional use and very expensive (>$1000). On Linux the free wireless tool Kismet brings limited intrussion detection functions with it.
There is only one way to watch the network from an other point then the AP. You need to sniff all traffic on the channel. On Windows there are special modified drivers needed to du so, on Linux most wireless drivers have the needed functions biultin or can be patched.
Thomas
Look at AirSnare...
Is there some reason you didn't reveal the make and model of your wireless router? They're not all the same and solutions of this sort tend to be unique to the device. See what fits:
Security is a good thing, or so I've been led to believe.
Surely it's worth $30. You'll probably spend days testing or writing software just to save a lousy $30. No wonder programming isn't the road to riches. Sigh...
See "Linksys Logging Utilities":
Sorry, my fault for not mentioning more detail. I have a Linksys WRT54G running 4 computers, soon to be secured via WEP.
Jeff : I tried Wi-Fi Defense and liked it. It's a shame that it's $30 to buy it though.
Does anyone know of any software similar to Wi-Fi Defense that is free?
Thanks.
Hi
If you are using the Router's DHCP, there is a menu in the Router that would show you the IPs that are logged.
If there is an IP that is not used by your computers then someone is leaching.
Be sure to use the security measures just in case:
Note, however, that someone programming up a static IP can still use your network without the DHCP server's logging showing it. Use the "Show me the connected MAC addresses" function instead of the "Show me who I handed DHCP addresses out to" function.
And yeah, turn on at least 128-bit WEP with a good random hex key.
