On Thu, 11 Dec 2008 16:40:21 -0500, "Peter Pan" wrote in :
Did I say that? .... nooooooo!
Separate from my plans to learn more about what kinds of equipment this facility is using to project its wireless signal and making efforts via the HOA and (later) the owner/operators to influence some revision of how internet connectivity is done, my current temporary, workaround plans are to:
- acquire a taller/longer omni antenna for my AP431W - fabricate a little parabolic reflector for that antenna - also take my AP421W & 25' of ethernet cable with me when I travel to visit
Then I could locate the 431 on the east end toward the signal with the taller antenna and the adjustable reflector on it positioned for maximum signal strength, connect the ethernet cable and extend it westerly toward the middle and west section of the boat and connect it to the 421 to act as an access point for the laptop.
The airlink illustrations and overview of the two multipurpose devices I have are here, which include illustrative Product Diagrams:
I also don't know much of anything about what I'm trying to do with the
421-431 ethernetted together.On Fri, 12 Dec 2008 09:36:19 -0800, "Mike Easter" wrote in :
Be warned that higher gain means smaller vertical beam angle, making alignment more critical, possibly a problem if the houseboat rocks much.
A corner reflector is probably a better bet.
Can be configured as a wireless Ethernet client bridge -- good.
Then start with just the high-gain omni, no reflector -- if that works for the remote connection, it might also be enough to illuminate the houseboat wireless clients in (ugh) repeater mode.
The setup is described in
:-) Seeing how much you love the repeater concept, you'll probably be ecstatic to learn that this wireless signal is without any password security/encryption - neither WEP nor WPA. It is just hanging out there.
Fortunately its location is rather remote in every direction from anyone except those who have access to the grounds thru' its gates. Even the lake part itself is kindofa created slough, not where general lake traffic is located.
And maybe this repeater will benefit those other houseboat laptoppers alongside who are also having significant signal troubles.
On Fri, 12 Dec 2008 11:33:32 -0800, "Mike Easter" wrote in :
Then of course you'll want to use VPN.
Or maybe it will reduce the speed of those now getting service.
If you really want to benefit the neighbors, use two radios (wireless Ethernet client cabled to wireless access point on a different channel): potential win-win for everyone.
Oh good. :-/ Something else I have no experience with. I understand the concept.
I'm pretty sure I don't understand that properly. Maybe it has something to do with interference, but I don't have a picture of how that might work. Maybe it would be based on what you said earlier about cutting the thru'put in half and (prior to the repeater) someone was getting 'full' thru'put unhalved until the repeater signal came along and was stronger and took over, but with only half as much data. Or something like that.
Out yonder at his home near this houseboat, my friend has an unused wireless router I'm now inquiring about. Besides my idea of taking along these extra experimental/ trial&error/ pieces consisting of the 421 and cable and reflector in addition to the 431, I'll get him to bring the router to the houseboat. There's also another sale at Fry's today - it's Friday - for an Airlink wireless router for $15.
AR430W - so-called SuperG 108
Buying any of this stuff where he lives doesn't (seem to) give access to any of these good deals.
On Fri, 12 Dec 2008 13:19:14 -0800, "Mike Easter" wrote in :
Something like that. :) You'll be doubling traffic. If a couple of boats are networking over the Wi-Fi they will immediately see their speed cut in half.
You don't need a router, just an access point -- the 431 and 421 will do fine.
