The built on XP client, or the client that came with your card should be all you need. If you want more or different ....
- Vote on answer
- posted
18 years ago
What? You asked for "Hot Spot Access control software free for windows". Are you looking for a free replacement wireless client that gives more control when connecting to various hot spots, or are you looking for software that will authorize and authenticate users of some undefined hot spot, as in security software? Replacement clients are avaialable from Boingo and T-Mobile. Authorization is normally done by the hot spot software or firmware. For complex hot spot systems, an external RADIUS server is normally used. I'm too lazy to supply all the possible hot spot software, configurations, and RADIUS server solutions. Could you supply some more detail at to what you're looking for?
where?
