It's a D-Link 614+ wireless router and a D-link dwl 520+ wireless adapter card. I can only receive a VERY weak signal from a distance of only 52 feet. It's broadband cable internet and the speed is about
60kbps [yes 60] with the wireless computer. The [wired] comp gets the normally high speeds.Should I buy a new card or router or both?
Can someone suggest a new wireless adapter that has excellent reception?
I really don't want to run wires if possible.
Can someone suggest some tricks/settings that I can change to make this work correctly?
Anyone have any suggestions please ??
