I need to connect two Windows PCs in my house via a high speed wireless connection. I need enough speed to play a dvd on one computer of of the drive of the other computer. A wired network is not an option due to physical restrictions. The machines are connected over wi-fi 802.11g, but this is not fast enough. Any ideas will be greatly appreciated.
Now exactly why is it impossible to use a wired connection, you can pick up ethernet cable in 100 500 1000 ft bundles. Even if you go with MIMO based gear, your limited to the speed of your optical drive ability to stream it to the network. I do have a feeling that MIMO will not solve your problem.
You might want to try this method:
Rip DVD to harddrive Use Daemon-tools on client to mount DVD, or DVD image. Watch enjoy.
This should work in a G network, depending on your system specs, for example the speed of your harddrive. I used to do this in 802.11b network and it was watchable not perfect but good enough.
On 22 Aug 2006 09:13:20 -0700, snipped-for-privacy@gmail.com wrote in :
Powerline networking:
Homeplug Turbo (NETGEAR XE103/XE104): typical 10 Mbps real throughout (equivalent to a good 24 Mbps 802.11g link), but up to double that if you're lucky
Homeplug AV: about 2.5x Homeplug Turbo, still vaporware
On 22 Aug 2006 09:27:58 -0700 snipped-for-privacy@iwon.com wrote: | | snipped-for-privacy@gmail.com wrote: |> I need to connect two Windows PCs in my house via a high speed wireless |> connection. I need enough speed to play a dvd on one computer of of the |> drive of the other computer. A wired network is not an option due to |> physical restrictions. The machines are connected over wi-fi 802.11g, |> but this is not fast enough. Any ideas will be greatly appreciated. |>
|> Martin | | Now exactly why is it impossible to use a wired connection, you can | pick up ethernet cable in 100 500 1000 ft bundles. Even if you go with | MIMO based gear, your limited to the speed of your optical drive | ability to stream it to the network. I do have a feeling that MIMO will | not solve your problem.
Lots of people prefer not having cables all over the place. It can also make a hazard, especially for children and the elderly. And wiring it in the walls is not always an available option.
Yep. "Fear of Wiring(tm)" is a common phobia. It's very evident in the display advertising for computer systems, where the photos rarely show any wires. There will be a typical office scene, where smiling lusers surround a desktop computer system, with absolutely no cables or wiring in sight. Not even a power cord can be seen. Obviously, the "Fear of Wiring(tm)" phobia is a serious and chronic condition that apparently can only be alleviated with a conscientiously applied program of wireless exposure.
I covered the problem in more detail in a previous rant:
No such animal, at this point anyway. If it ain't fast enough you'll have to consider other options. Simplest being sneaker net and a second DVD player in the other PC. Or rip the DVD to the local PC's disk and once that's complete, pull it over to the other PC for watching.
What are you trying to actually do? There may be other solutions for dealing with it from an A/V perspective.
Whats wrong with 108mbps wireless or the "N" My N router works great. Yeah, I know It's not set in stone yet. By the time It Is, It will be time for new one anyway.
On Wed, 23 Aug 2006 16:20:19 GMT, Kevin Weaver wrote in :
What's wrong is that such high speed is only possible over a very short range without much interference. Throw in some distance, interference, and/or walls, and speed will be much less.
On Wed, 23 Aug 2006 19:54:18 GMT, Kevin Weaver wrote in :
You mean 27 Mbps and 20 Mbps? Is that measured throughput under heavy load, or the raw speed report? (If the former, how did you convert from bytes to bits?) Many wireless adapters report a high speed when idle, but are much slower under load.
I'm going by what it reports in the task bar from the netgear icon. It will show 270mbps and at times will show 200mbps. The range and speed is much better then the linksys and netgear ones I've had in the past.
For the person asking: If going this route ask if it can be returned if it does not work for you. If it does, great. If not, nothing lost.
Why wireless? The netgear XE103 (at ) runs at 85 Mbps, and the HDBX101 at does up to 200 Mbps (powerline networking)... If you absolutely have to have wireless, use the high speed powerline stuff as a bridge and throw a wap on each end and bingo, instant high speed wireless.
FWIW I have and use the XE103's and they work great with a wap/router on each end (same ssid so I have a large hotspot at my house), the 101's have only been out for a few months and I haven't used the newer models so can't say if there will be any probs with them (none so far with the 103's)
On Tue, 22 Aug 2006 17:40:52 -0700 Jeff Liebermann wrote: | snipped-for-privacy@ipal.net hath wroth: | |>Lots of people prefer not having cables all over the place. It can also |>make a hazard, especially for children and the elderly. And wiring it in |>the walls is not always an available option. | | Yep. "Fear of Wiring(tm)" is a common phobia. It's very evident in | the display advertising for computer systems, where the photos rarely | show any wires. There will be a typical office scene, where smiling | lusers surround a desktop computer system, with absolutely no cables | or wiring in sight. Not even a power cord can be seen. Obviously, | the "Fear of Wiring(tm)" phobia is a serious and chronic condition | that apparently can only be alleviated with a conscientiously applied | program of wireless exposure.
Well, there you go; there's your ad campaign for wireless ubiquity.
Of course some people just think it's ugly to have all the wires around.
| I covered the problem in more detail in a previous rant: |
About a year ago I found a big brown spider living deep under the wiring behind my computer desk. With 4 computers, a SCSI drive tower, 8-port switch, KVM switch, there are a few wires running around back there on the floor. At least I have one advantage that the KVM switch uses DB-25's and special cables that have DB-25 on one end and fan out to dual-PS/2, DB-15, and a couple plugs for sound, that make the problem not as bad as it could be. Yet that spider did find a home. No idea how long he/she had been there.
In some ways, wiring is good to have. I know I can take a computer offline from the net for sure by just unplugging it. in other ways it is bad. My mouse cable does sometimes cause some drag.
I didn't have room for a printer in this little computer room. So I put it in another room. Not wanting to run a wire out to it all over the place, I simply bought a printer that was wireless and started using it that way. Keeps things sane. When I'm doing stuff that needs a lot of document reviewing, I set the printer on the dining room table and use that table to sit and read away from the CRT screen. At other times it can sit on a shelf in the laundry room for light duty occaisional printing.
Well, that's typical. Programmers always blame the hardware when they find a bug.
On occassion, finding a bug is benificial, as big bugs get that big by eating smaller bugs. It's a pity that the programming industry hasn't recognized the benifits of cultivating large bugs, that tend to obscure the smaller bugs.
I have several wireless mice but have switched back to wired. The problem is battery power. The Logitech piece of manure I purchased for my laptop is turned on/off with the attachment of the USB dongle in the base of the mouse. This prevents me from leaving the mouse connected for extended periods causing the battery to drain. It also tends to fall out in my laptop bag. I think of this as a mechanical bug. On my desktops, I've had battery life and KVM switch problems. I would probably consider a wind-up mouse at this point.
Wireless headsets is one area where wireless would really make sense that I can't get to work reliably. I can get Bluetooth and 802.11 to coexists but not reliably. The problem is that Bluetooth technology is excessively complex for the purpose intended. A relatively simple
46/49MHz or 433MHz conventional FM modulated cordless headset would work much better. Like the wireless mouse, battery life is an issue.
I just had the same problem at an auto repair shop. The ancient Sun diagnostics machine (running Windows 3.1) had a very small Alps dot matrix printer in a drawer. The owner wanted a laser printer, but couldn't find one that fit in the drawer. I found an old Okidata 410e printer that barely fit. Many of the older Okidata laser printers are very small. I'm sure you could have found one to fit in your computer room.
Yep. "Fear of Wiring(tm)" in action again. It's so pervasive that some people will even purchase new hardware just to avoid wires and cables. If you can't stand the sight of wires, perhaps running them outside the house (through a convenient window) might be acceptable?
CRT screen? As soon as Intel delivers UWB chips the traditional 2 years later than promised, you'll have wireless video. Then, you can bring your display to your printer instead. Meanwhile, you can always run VNC or some remote desktop software on a laptop in order to avoid seeing the CRT cables.
Condensation from the washing machinery will not do the laser printer much good. However, if you're counterfieting money on your printer, proximity to the washing machine (necessary to age the currency) is certainly handy.
| I'm going by what it reports in the task bar from the netgear icon. It | will show 270mbps and at times will show 200mbps. The range and speed is | much better then the linksys and netgear ones I've had in the past.
But can ypu actually transfer a 4.7GB file in 139 seconds? That's what "270mbps" implies. I think not. I'm not even sure how you get this value of 270 in the first place. The bit rate when sending a frame over the radio is one thing. But there are lots of time cycles in which there is no transmission taking place.
What throughput are you seeing. Using Ixia Qcheck to measure TCP throughput and a pair of Airlink101 MPL8511 powerline extenders, I can get 15Mbps if the two are on the same powerstrip but only 500kbps if they are on different AC circuits in the house :-(
