Hello,
I have a Linksys WRT54GS wireless router, connected to comcast Zyxel prestige 900 cable modem router, and a 15DBi omni-directional antenna hooked to the linksys router.
My dilemna is that the High gain antenna seems to be giving me little or no signal. I've attempted the following.
-disable/reneabled DHCP on Linksys
-Changed through all channels on Linksys
-disabled mixed frequency mode on Linksys
-Tried two different Antennas on Linksys(to include the ones it came with)
Here's the thing, I can stand right next to the router with the high gain antenna hooked up, walk 30 feet away in a direct line of sight and then the signal drops to two bars. 50 feet away signal is 1 bar and not enough strength to get on the net.
Any clues/help will be greatly appreciated. This one is throwing me for a loop. I've set up wireless networks in the past and haven't this one before!
