High Gain Antenna for Netgear??
Hi All:
I'm needing a slight boost in signal strength from my Netgear WGT624 wireless router. Does anyone know if there is a high gain antenna product that would work with this router - either from Netgear or a third-party? I haven't found one but thought I'd ask. (I know Linksys and D-Link have high gain antenna products for their routers - you would think Netgear would also.)
Thanks in advance.
Sid Joyner
Does your Netgear router have a removable antenna? If so, you've got lots of options. If not, you'll need to get a different router.
Mike Schumann
Mike Schumann
Or you can use a DIY reflector from here:
Doz
