Hi
I am running win 2k, I have WUSB12 installed. It keeps wiping out the WEP key. I can not keep it functioning, functions for awhile, then quits. Bad signal strenght, Very hard to switch the LAN connection to (available) on. Please advise what I am doing wrong
TIA
Mike
Configuration:
Infrastructure Mode Acess Point SSID Linksysa Transfer rate Auto Channel 6 IP DHCP WEP Key 64bit
