When I try to enable any of the security features I get a message that the SSID is already configured and to enter a new SSID and network connection.
When I do this it will not connect to the AP even though it shows it with a good signal. I have duplicated all the same info on the router/AP. D-Link had been no help when I have called for assistance. I have deleted the old SSID and all info prior to creating the new SSID with security enabled.
I am banging my head against a brick wall.
The computer is a Win 98Se but that should not matter as I am only working with the D-Ling configuration utility.
Thanks for your help Jim
