Hi all:
I bought a Hawking Technolgy HWR54G Wireless-G Router and D-LinK Wireless PCI card for my laptop. I installed the Router no problems and after 5 min on the phone with Rogers it was set up.
Then I realized my replacement laptop does not have a PCI card slot (oops) AFTER I installed the driver on the CD (my fault!) so off i went to the computer shop again and got the Hawking Mini-Wireless-G USB 2.0 Adapter. Installed the driver, restarted and installed the USB device. I was surfing the net in no time!
Then i decided to delete the DLink driver from the laptop which i did. Then the trouble began. Now I cannot get on the internet on the laptop, yet i can still access my company's intranet website via the internet and navigate that. (Weird) I tried to remove the Hawking driver for the USB device but it will not uninstall using the add/remove programs option on Windows XP. (Can anyone tell me how to manually remove the driver and software and start again?)
Any help/suggestions greatly appreciated.
Clyde '
