bit of a strange one, apologies:
I have a USR 22mbps Access Point and 2 wireless laptops:
- Laptop 1 sees the AP (among 4 of my neighbours), can connect ok, and browse the internet just fine.
- Laptop 2 sees just 3 of the neighbours' APs... not my one. And (with my neighbours' unsecured networks) it can connect fine to the internet.
Strange thing is that the Laptops are physically beside one another and beside the AP, so there can't be any range issue.
I've tried 'repair connection', got an error about DNS not able to be cleared, successfully flushed DNS using CMD -> ipconfig /flushdns
The DNS service is set to Automatic in the Control Panel ->
Administrative Tools
I'm at a complete loss as to why one PC can see the AP broadcasting and connect ok, and the other can't see it.
Can anyone offer any tips or advice?
Thx, Narbo
