I came across a spool of some very small coax in the hopes that it could be used in 802.11 but now not a clue of what it is. It is on a Raychem reel. The Description tag says 5028A1318-0 440086. As best I can measure it is
0.075 inch OD, 0.055 braid diameter, 0.040 insulation OD and the center conductor measures 0.015. The outer jacket is black and the inner insulation is tan in color. The braid is very dense fine wire as is the center conductor. It looks and feels like high quality stuff. Any help or even a good guess appreciated.- posted
18 years ago
