Hi everyone
I need to extend my wifi to another part of the apartment, so I have this set up:
modem --> PLC (Power Line Carrier)..........................PLC (Power Line Carrier) --> Access point
Here is the hardware: Modem: Came with my ISP's internet PLC (My Power Line Carrier) : BeWan Powerline E85 Access Point: Netgear WG602v3
So basically, I am trying to send my internet over the powerline. The internet is then picked up by an Access Point in another room, which I plugged into a second PLC. The access point is connected to the PLC via an ethernet cable.
I would like to be able to access the internet from the wifi on the access point.
I have followed the instructions here, but it still dosen't work:
I am unable to connect to the internet... I also get an error saying that the IP address is invalid from windows.
Does anyone know what I should do?
Thanks
Zach
