I am using a linksys WRT54GSV4 wireless router with WUSB54GS wireless usb adapters. I am using WZC instead of the linksys software because I'm having an issue with roaming profiles and the WZC was a suggested fix. Every time I reboot a machine I have to disable and re-enable the connection before I can receive data. The connection makes, because the icon in the system tray reports that I am connected with good signal strength.
I think the issue is encryption related because the network adapter reports itself as connected, but I am unable to receive data. I can't ping any other machine on the network, nor the router. If I wait the
3600 seconds (1 hour) for the key to be regenerated I will connect (rather begin to receive data), or if I disable and re-enable the connection I will connect. This happens with AES or TKIP.It doesn't happen when I use the linksys software, and I know that I could just install it and use it, but I want to fix this issue with WZC. I could just repair the connection every time I boot, but that defeats the purpose as that would not allow me to pull down the profile.
This happens on two different machines, using either AES or TKIP, both machines have exactly the same symptoms although one machine uses a WUSB54GSC.
Has anyone seen this with WZC?
