I have a wireless network set up with Linksys WRT54G and an older Thinkpad with a D-Link adapter card. Security installed, everything works fine. Now I just bought a new Acer notebook which of course has 80211g installed, and I want to add it to the network. I need some real simple instructions--all I find on the web is complicated, looks out of date, or assumes I'm starting from scratch.
Do I need to install the Linksys hardware to the new computer, and then go ahead using the Easy Install routine or the wizard? Do I have to connect to the router with an ethernet cable untill I get it installed?
