Help?
Threaded View
Posting for a friend...............
She just got a Dell Latitude laptop and needs to get online.
I've never owned (or used) a laptop so my experience doesn't
help her one bit. Anyone hve any input on this? She sure
could use the help.
Thanks,
Dusty
Re: Help?
Get a broadband connection via your local ISP and either ethernet into the
laptop or go wireless.
> She just got a Dell Latitude laptop and needs to get online. I've never
> owned (or used) a laptop so my experience doesn't help her one bit. Anyone
> hve any input on this? She sure could use the help.
> Thanks,
> Dusty
Re: Help?
>>Thanks,
>>Dusty
> Ok, I passed that along and that's her idea too. She has no clue
  what additional hardware is required. Router, wirless
adapter, both?
Re: Help?
Depends. If you want to keep the laptop in one place then no other hardware
is needed, as all you need to do is connect the laptop into the broadband
modem using a ethernet cable. If you want to go wireless, you need a
wireless router and a PCMCIA wireless adapter for the laptop, unless it has
built in wireless.
You can buy a wireless 802.11b router and PCMCIA card for about 30 to 50
dollars, depending on manufacturer and sales goin on. You can buy a 802.11g
router and PCMCIA card for between 50 and 100 dollars also depending on
those previous mentioned variables. Another good place to buy the equipment
is on EBAY. Sometimes you can get one great deal. I bout a D-Link 514
802.11b wireless router unopened for 12 dollars with free shipping. Cant
beat that.
I personally like D-Link, but others like Linksys, Belkin, Netgear and the
countless other manufacturers.
Anything else I can help with just ask......
Robert....
>> the laptop or go wireless.
>>>Anyone hve any input on this? She sure could use the help.
>>>Thanks,
>>>Dusty
>  what additional hardware is required. Router, wirless adapter, both?
Re: Help?
Glad to see someone else with a D-Link preference.  Sometimes I think I'm
the only devoted "D-Linker".
Other than a few firmware-related hiccups (especially getting those
DWL-7100APs working together!), I have no major complaints.  All my D-Link
stuff, for the most part, has become rock solid after properly config'd and
tweaked -- even though digging for the more technical information off D-Link
can be a sport in itself.  Guess thats half the fun though.  :^)
Cheers!
Re: Help?
I'm not a D-Link lover, although I have two DWL-122 USB dongles.
I think DLink, Netgear, and Linksys are interchangeable.
I bought a Netgear "g" package after buying a dead Netgear "b" and
returning it.  At this price range, it's all about price, and at this price
range, it's all about rebates.
Netgear WGB511 802.11g Wireless Networking Kit $74.99 - $25 = 49.99
WGR614v4 Router and WG511 PCMCIA card that I have.
<(Amazon.com product link shortened)>
This setup works well with WindowsXP.  I did have to upgrade the drivers
for the WG511 card, but that was simple enough.
Clarence A Dold - Hidden Valley (Lake County) CA USA  38.8,-122.5
Site Timeline
