Hawking Technology's Hi-Gain USB Wireless-G Adapter (HWU54D) gets hot?
Hello!
I noticed my new Hawking Technology's Hi-Gain USB Wireless-G Adapter (Model: HWU54D --
) gets hot after a long period of usage. I can't touch its base for more than ten seconds. Is it normal? I think it locked up this morning (only once so for a week since I bought it and installed it), and I had to disable it via Device Manager and re-enable. This was in a 75 degrees(F) room.
Other than that, this wireless USB adapter seems to work decently.
Thank you in advance. :)
ANTant
My DLink DWL-122 mini-USB gets a lot warmer than I expected, but it doesn't seem to suffer from it.
dold
