Hi All,
Hope someone here can help. I am having a problem with the following setup:
Dlink 502G : in half bridge mode, so as I understand it, it should terminate my PPPoA connection, but pass on the real world IP to the DD- WRT. Address to access setup pages is 10.1.1.1. Is being assigned dynamic IP's by ISP.
DD-WRT : Getting the real world IP from the Dlink 502G ok. Setup pages is 192.168.1.1. Assigns IP's to clients in the range 192.168.1.100.
Now the problem is that when the Dlink 502G resynchs, for whatever reason, the new IP is not being passed on to the DD-WRT. I can fix this by manually going into the DD-WRT setup pages and clicking on DHCP renew, but I am assuming it shoud be updating the IP after a resynch automatically?
Anyone have any suggestions?
I will try to post some links to screen shots of the setup later.
Cheers
-Al PS: DD-WRT running on Linksys v1, V24 stable.
