I can't connect with fixed IP on a WPA Wireless network. Roaming and automaticly assigned IPs work but when I try to set the two wireless machines to fixed IPs they won't connect. (one is WinXP, other Ubuntu) Gateway is 192.168.2.1 a wired machine is ...2.2 and I wanted the two wireless ones to be ...2.3 & ...2.4 (I wanted to do it for port forwarding.)
Any ideas what I should be looking for?
TIA
Slatts
