Hello.
I know this is the most common query out here, but I've not quite found the solution in my reading various posts. So, at the risk of repetitive, I'll put my problem out there.
We live in an old four-story house with brick and plaster walls. the DSL modem and wirelessRouter #1 are in the Rear end of the 2nd floor. Wifi reception all along the front side of the house (floors 1-4 is low at best, usually Zero.)
I am trying to figure out how to best extend the range to reach these corners.
- I can't really move the modem and Router#1.
- Nor can I run ethernet to a point where I could set up a second access point (if I am reading correctly, a second wireless AP MUST to wired to the first router. if that is NOT correct, could someone explain how to set up a standalone, unwired AP?)
- I have several wifi routers and DSL modems.
- there are telephone jacks all over the house.
So, Question (beyond the "how, given the wiring constraints, best to set up another AP?"):
- can I plug a second DSL modem into one of the other telephone jacks and attach another router to that modem and have a working second AP that way??
many thanks
Peter
