No, just an explanation. In Windoze XP, Microsloth instroduced Wireless Zero Config which is what you're looking for. It's only available for XP and has not been released for W2K. Sorry.
It would actually be fairly simple to write such a utility as all it does is act as a front end for NDIS 5.x calls. However, nobody has seen a need for the older operating systems, and XP already has one (WZC) that works.
Yep: C:\\WINNT\\system32>wzcsetup Usage: wzcsetup /i /u /i - to install the WZCSVC component. /u - to uninstall WZCSVC. However, it may not be Wireless Zero Config despite the name. It's part of the 802.1x authentication package. See:
note the list of files included. Looks like they started to do Wireless Zero Config for W2K, but stopped for some reason.
Donald Davis suggested using the Boingo client. That will work.
T-Mobile also has a client program:
There's also McAfee free WPA client at:
can act as a connection manager.
IBM has their ThinkVantage Access Connection front end. Toshiba has their Config-Free program, which is not exactly a client manager but is close.
