Ok so my connection has been playing up over the past few days, I really have no idea whats wrong with it. The connection appears to be "dropping" every few seconds, which I confirmed by trying to ping my default gateway, which returned high ping times and "General Failure" every so often.
The problem doesnt seem to happen all the time,
I've tried reinstalling drivers already but no luck there, same problem. I'm going to just give as much info as i can and hope someone has some idea of how to fix this, its driving me nuts! :mad:
::*_Information_*::
_OPERATING_SYSTEM_ Windows Vista 32 bit
_ROUTER_ SpeedTouch 585v6
_NETWORK_ADAPTER_
*Name:* Atheros AR5006EG Wireless Network Adapter DRIVER VERSION:[/B] 7.3.1.109 [B]_IPCONFIG/ALL_ Microsoft Windows [Version 6.0.6000] Copyright (c) 2006 Microsoft Corporation. All rights reserved.Windows IP Configuration
Host Name . . . . . . . . . . . . : LiamsPC Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . : lan Description . . . . . . . . . . . : Atheros AR5006EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-16-E3-AF-65-CD DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::6d3d:35a0:e360:ef7f%12(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.65(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : 21 November 2007 17:23:28 Lease Expires . . . . . . . . . . : 22 November 2007 17:23:28 Default Gateway . . . . . . . . . : 192.168.1.254 DHCP Server . . . . . . . . . . . : 192.168.1.254 DHCPv6 IAID . . . . . . . . . . . : 201332451 DNS Servers . . . . . . . . . . . : 192.168.1.254 NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection Physical Address. . . . . . . . . : 00-A0-D1-66-5F-CA DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
Tunnel adapter Local Area Connection* 7:
Connection-specific DNS Suffix . : lan Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.65%13(Preferred) Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 192.168.1.254 NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 9:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{BB5107DF-0CF9-42B8-B2DF-766AA42FC6B3} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
_PING_192.168.1.254_-N_1000_ Ping statistics for 192.168.1.254: Packets: Sent = 1000, Received = 832, Lost = 168 (16% loss), Approximate round trip times in milli-seconds: Minimum = 1ms, Maximum = 1054ms, Average = 26ms
_PING_GOOGLE.COM_ Pinging google.com [72.14.207.99] with 32 bytes of data:
Reply from 72.14.207.99: bytes=32 time=120ms TTL=242 General failure. Reply from 72.14.207.99: bytes=32 time=122ms TTL=242 Reply from 72.14.207.99: bytes=32 time=131ms TTL=242
Ping statistics for 72.14.207.99: Packets: Sent = 4, Received = 3, Lost = 1 (25% loss), Approximate round trip times in milli-seconds: Minimum = 120ms, Maximum = 131ms, Average = 124ms
