router is belkin wireless G+ MIMO
card i might get is
belkin wireless G+ network card (searching wireless card was good)
So, The router is G+ MIMO the card is G+. Both belkin.
is the card compatible?
would I lose the MIMO function/ability? and will that effect signal level?
does the card have to be belkin (I heard that + is proprietary. If I didn't use a belkin card, would it still work but i'd lose the + ?)
