My Acer Aspire 3003 laptop works fine when connected using the inbuilt Ethernet port for all applications including FTP uploads using SmartFTP or a an FTP program built into some application software I have. When I fit a Netgear WG511T Cardbus card this works fine for browsing and email. However, if I try to use an FTP program such as Smart instead of the Ethernet card neither of the FTP programs will work. I am using WPA with a 128bit preshared key. This is true if I use the standard Windows drivers for the card or the ones supplied by Netgear. I am running a fully patched Windows XP Home and the machine has 1GB of memory. AFAICS there must be some incompatibility be the FTP protocol and WPA but I cannot see why that should be. I would expect the WPA protocol to be transparent. Any constructive suggestions would be welcome as my Googling has not turned anything up.
Peter Crosland
