After some testing with a PCMCIA wireless network card I like to have a wireless bridge ( client ) for the same purposes as the PCMCIA card is used. No big deal I thought, now I found out, most of these bridges not nearly have the possibilities as any cheapo PCMCIA card or USB dongles have. An IMHO very elementary option to just scan for available networks or hotspots show no signals strength or isn't available at all!? Some senao models (like 3054) looked promising but these simple options like showing the signal strength isn't there according a reseller. (I must say I have a hard time believing that.) Some other models like linksys WET54G have only 60 mWatt from the already limited 100 mWatt allowed.
Hopefully anyone here has a model that suit my needs. What I want is : Use it as a wireless client to be able to connect to hotspots see many abbreviations like P2P multi point and what not. I only want an internet connection from hotspots and connect this bridge to a network ( router ) so that all computers have internet access.
An OS independent model( HTTP configuration )
100 mWatt power connecting a external directional antenna. WEP and WPA B and G band Scanning for available hotspots or networks. See the strength of these networks. See what security they use. Selectable channels preferable working on 12 voltsOutdoor models are fine too as long as it isn't twice or ten times the price from an indoor model.
If there is any analyzing software working with such a wireless bridge that should even be better Suggestions are highly appreciated. If it doesn't met all my wishes but you have a good experience with some model , I like to know about that too.
Sorry for the long story.
