i have to connect an ethernet device in a wireless network. I've tried with D-Link AP 900 as a wireless client and it runs ok IF the network AP's are D-LINK. There's some other low cost device running with every AP brand?
thanks
thanks
Are you thinking out loud, or was there a question? WET 11 DWL 810+
Brunt hath wroth:
I think you mean Dlink DWL-900AP+. The client mode in the DWL-900AP+ is not the greatest. I've had problems trying to get it to connect to some access points. For example, my DWL-900AP+ has no problem connecting to my BEFW11S4v4 but refuses to stay connected to my WRT54Gv1.1 with DD-WRT firmware.
The DWL-900AP+ uses the TI ACX100 chipset. Finding a wireless access point with a similar chipset is not difficult:
I don't know of any client device or ethernet bridge that is 100% compatible with everything.
I have a Buffalo Ethernet to Wireless converter that works fine with a Netgear router. But it isn't an access point used as a client. AFAIK not all access points have a client mode, though many do.
yes
that's my problem. I can'e use it in another network with different APs
wonderful!!!
Others than DWL-900?
