Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by ted on July 1, 2008, 12:37 pm
Please log in for more thread options + wirelesscard wpc54g v3.1 with wxp with patch to use wpa/wpa2 I think that authentication in my radius pass correct but there is some problem with wpa mode or wpa compatibility In my ddwrt I try mode: wpa-enterprise, wpa2-enterprise, wpa2 enterpise-mix and radius. In my wirless card a try: wpa and wpa2 below my freeradius.conf: andy Auth-Type := Accept, User-Password == "andy" and log from radius: rad_check_password: Auth-Type = Accept, accepting the user Login OK: [andy] (from client wrt54g port 0 cli 00-18-F8-aa-aa-aa) Sending Access-Accept of id 4 to 10.0.0.6 port 1026 my wrt54g still send to syslog: klogd: @ = Add Host : [00:18:f8:aa:aa:aa] VID 9 LinkID 1 PortNumber 6 klogd: @ = Add Host : [00:18:f8:aa:aa:aa] VID 9 LinkID 1 PortNumber klogd: @ = Add Host : [00:18:f8:aa:aa:aa] VID 9 LinkID 1 PortNumber 6 and i never connect to network and i must still (every 30s) type login and password to authenticate When i use only wep, without radius,it's works. I use all may ports 4xLan+1XWan in vlan0 as the switchport. I try setup radius+wep/wpa in wrv200 but the problem is the same I have dwl900ap+ from dlink and when I use radius + wep 64bit everything works i don't have any idea thanks for any help | ||||||||||
| Similar Threads | Posted |
| wrt54gs with freeradius | October 18, 2004, 9:34 pm |
| freeradius 2.x + 802.1x + wpa/wwpa2 + win xp | July 1, 2008, 12:37 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
