If the following error occurs when attempting to run IPCONFIG when using a wireless network adapter:
The likely problem is a wired network adapter that isn't connected, and as a result has been automatically Disabled in Network Connections by its network driver, while still being enabled in Device Manager. IPCONFIG reports an error because the wired network hardware is enabled but it can't get the media status since the Network Connection (driver) is disabled. (Turning off Power Management doesn't help.)
This issue is known to affect at least some Intel wired network adapters with Windows XP drivers dated 2006 and later. For example, a disconnected Intel PRO/1000 MT Mobile wired network adapter in a ThinkPad T41 stays at Network Cable Unplugged with driver e1000325.sys
6.4.16.36 (06/13/2003), which allows IPCONFIG to work, but switches automatically to Disabled after about 30 seconds or so with any driver dated in 2006 (e.g., 8.7.1.0 [04/27/2006] from Microsoft/Windows Update, 8.7.9.0 [10/24/2006] from Lenovo), which causes IPCONFIG to fail.Fix:
- Use Windows XP Driver Roll Back or Uninstall/reboot/reinstall to go back to the original Windows XP driver, or otherwise install an old driver that doesn't exhibit this problem. * Hide any updated driver in Microsoft/Windows Update to prevent unintentionally recreating this problem in the future. Likewise avoid driver updates from hardware vendors.
Workarounds:
- (Verified) 1. Click Start > Control Panel > Network Connections, and for any wired network adapters that are Disabled: 2. Right-click on My Computer, and click Manage to start Device Manager 3. Disable wired Network Adapters that are disabled in Network Connections 4. Run IPCONFIG as desired 5. Re-Enable wired network adapters in Device Manager
- (Verified) 1. Click Start > Control Panel > Administrative Tools 2. Double-click Services 3. Scroll down to Routing and Remote Access 4. If Routing and Remote Access is Disabled, change it to Manual 5. Start Routing and Remote Access, or Stop and Re-Start it if it's already running
- (Not verified, applies to ThinkPads, possibly other computers) 1. Uninstall Access Connections, Keyboard Customizer, Wi-Fi drivers, and Ethernet drivers 2. Reinstall in this order Ethernet, Wi-Fi, Keyboard Customizer, Access Connections
