Apologies if this is a bit simple, but I can't find the mac address of my wireless PC card (on my laptop). I've tried ipconfig/all (I run XP) but the wireless card does not appear. I have another bit of software from my internet provider that says the wireless pc card is NOTCPIP (I assume this means no TCP/IP). However, the wireless card works fine (I've been using it for over a year!) I can find the wired network card (which also works fine). Any suggestions?
- posted
19 years ago
