find access point MAC address
On Thu, 18 Nov 2004 11:41:40 +0000, Mark McIntyre spoketh
That would only be the case if the access point is also a router ... That is mostly a home-user solution, and this doesn't sound like a home-user problem, because if it were, he would know the IP address of his own device.
Since access points are transparent bridges, it won't show up in any traceroutes or arp tables, so the only way to get this information is to ask the person who would know: the network administrator.
Lars M. Hansen
'badnews' with 'news' in e-mail address)
Lars M. Hansen
Hi, I connect to a network through Access Point. I need to recognize the AP
that I conncet to. A possible way is to get the MAC address. Can
someone help me with a source code to do that.
jiten
jiten dash
The AP is frequently your default gateway - type IPCONFIG to see that.
If not, tracert might help - it shows you the IP of each machine you connect via, when going to a website. You could then convert the IP to a mac using nbtstat. Both tracert and nbtstat are commandline tools - open a command prompt and type them in.
Mark McIntyre
(of using tracert)
agreed.
yup.
Mark McIntyre
