Some mail servers use IDENT to authenticate the sending machine. My ancient UUCP over TCP system does that and will not work with IDENT turned off. If your email stops working, IDENT may be the problem. Systems using a Squid cache also tend to use IDENT as it's on by default.
Some reading:
