Is anyone else having problems accessing the "detailed" information under "Authorisation Search" as I unable to access manuals,photo's, etc. Under FF3.6.6 I keep getting "You are not authorized to access this page." and IE8 just gives me a blank page.
The trick is to think like a beginning programmer. For example, I just tried: Q87-WAG54GV2M as Q87 and WAG54GV2M in each box. Didn't work. However, if you type a -WAG54GV2M into the 2nd box (note the - sign), it works. Duh...
Anyway, all the detail shows in both FF and IE8. No error messages of any kind. I also tried 3 others, that also work. I the past, the FCC database has gone insane, but that seems to only happen on weekends, when nobody is watching. It magically gets fixed on Monday morning, when someone arrives to reboot the server.
Both of these. No matter who I choose as the applicant as soon as I click on "details" for a product you get the usual headings "ext photo", "int photo" etc. however clicking on one these produces a page which says " You are not authorized to access this page". For e.g. FCCID PY308100078 User manual
Displaying the details on the first item yields the usual list of documents. Punching the "user manual" results in the WNDR3300 wireless router manual. No error messages. The associated link is:
is the same as what you posted.
The problem is that you can't go directly to that link without first dropping a cookie on your machine announcing that you have approved the wholesale limitations of liability and responsibility demanded by the FCC before you can view public documents under the Freedom of Information Act of 1966. Enabled cookies, start at the top at
fill in the blanks, approved the disclaimer, and then it will work.
I must have a problem with FF as cookies for the FCC are always accepted. I have just downloaded Opera and I have no problems acquiring the data with cookies disabled or enabled.
For the last couple of years I have had the sendreferer header in about:config set to "0" and it seems that the FCC website doesn't like this. Modifying the sendreferer header to "1" allows me to access the data. Strange that I didn't have problems prior to FF3.6.4-3.6.6.
Nice troubleshooting and sorry about the wrong cookies guess.
The default is "2".
Those concerned with privacy can set this to 0, realizing that this may adversely affect some sites. Those wanting to ensure compatibility should leave it at the default. I think the FCC might be using logging software that records the refering web page. Why not having this information should cause and authorization error is rather mysterious.
Good to know. The first link works without going through the approval process, so just inserting the document ID number into the first URL format should be suitable for providing a direct link. I just tried randomly changing the document ID and it seems to work.
Incidentally, viewing any page does drop a cookie, fjallfoss.fcc.gov JSESSIONID, on my machine. It's set to expire at the end of the session. However, removing the cookie doesn't seem to do anything.
