Now with pictures!
Subject
- Posted on
Failed upgrade of firmware
- 06-22-2007
Re: Failed upgrade of firmware
Peter Boosten wrote:
Which version firmware were you upgrading to? I thought the "Default
Application Image" was supposed to run on "boot up" if the "Primary
Image" was corrupted and this should allow you to re-install the firmware.
"The access point stores two software files in its flash memory. One
has a file name such as hp420-2100.bin, which is the current version of
software the access point runs. The current software file is overwritten
when new software is downloaded to the access point. The other software
file, called dflt-img.bin, contains a default version of the access
point software that is used if the current software file is deleted or
fails. The dflt-img.bin file cannot be deleted from the system or
overwritten."
ftp://ftp.hp.com/pub/networking/software/420-RelNotes-217-59906007.pdf
You may find something of use here:-
http://www.hp.com/rnd/training/technical/420_WAP.htm?jumpid=reg_R1002_USEN
Kev,
Thanks for your answer. I tried to upgrade to hp420-221.bin (latest), did not
touch the boot software (3.0.6). The thing is that neither the console port,
nor the reset button seem to function. It get's an IP address however (the
one I assigned to it), I can ping it. The only open port is 80, but any
attempt to connect (either by browser or by telnet) times out.
tftp upload went smooth, answered 'no' to use default settings, did a 'dir'
and then reset board. After that 'nada' (have done firmware upgrades before,
without any trouble).
Any ideas?
TIA
Peter
http://www.boosten.org
Mail: peter at boosten dot org
Site Timeline
- » Use a wireless router as a repeater for a laptop?
- — Next thread in » Wireless Networking
- » Is it possible to use a router as a relay station
- — Previous thread in » Wireless Networking
- » Can you get a USA Ham Radio license WITHOUT giving the gob'ment your SSN?
- — Newest thread in » Wireless Networking
- » Starlink
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
