Hi, I have seen several threads about this, but they could not help with this problem.
I have two Voyager 2091 wireless routers. One is downstairs, connected to the DSL. Signal is weak upstairs and I would like to use my other router to act as repeater. So, I will have my laptop connect wirelessly with my router upstairs, which will relay everything in/out to the router downstairs wirelessly.
I have tried many suggestions on the previous threads, none worked:
- On the same channel with different SSIDs, while setting each as repeater of the other.
- Turning off DHCP on router upstairs and assigning it a static IP, while setting each as repeater of the other.
- Connecting my laptop with the router upstairs via ethernet cable.
- ..etc.
I believe the problem lays in the wireless connection between the two routers.
Thanks
