I have an ethernet converter in my garage that talks to the AP in the house. I put a directional antenna on the ethernet converter which helped improve the signal.
I have a PC hooked up to the ethernet converter with a hard wired cable. I want to be able to use another laptop in the garage without haveing to run another cable. Is there another device I can add to the ethernet converter that will act like an AP so I can use wireless in the garage?
Thanks.
