I have and EtherAnt II which I can access through the crossover cable and using the install program set by YDI. It is a sealed unit without a reset button. When I try to install, I need a password, but don't have one. It is used (obviously), bought on Ebay.
I see a response in another thread from a Bob which says he may be able to fix another one. Can anyone help, including Bob?
Thanks, Dave
