does anybody know how to fix an etherant ll antenna it wont link to my network
- posted
19 years ago
I do believe if I tried I couldn't write a post with less information in it.
Kind of interesting "Etherant II" - a wireless bridge.
EtherAnt II comes from several vendors. Which one sold the device? Did you get it from a wireless ISP? If so, call them first.
I've disected an EtherAnt II and suspect that it will be rather difficult to repair at the component level. You should make every effort to determine if the problem really is the EtherAnt II and no the wiring, cable, path, computah, power supply, etc. Your wireless ISP should also be contacted for advice or help before sending it in for repair. Judging by your sparce description, you'll need some local help to deal with the issues. Find someone with a clue and have them inspect your system. There are plenty of things that can screw up besides the radio that can prevent connectivity.
