hey folks--
can someone suggest the right equipment to get a wireless signal to be picked up from 500-1000 feet ? i have a large farm and want to get wireless into our barn/office from our primary house.
thanks {eter
hey folks--
thanks {eter
On Wed, 9 Aug 2006 19:14:49 -0400, "Craig" wrote in :
Do you have unobstructed line of sight? If so, standard equipment with good high-gain antennas on each end, mounted as high as possible.
Thanks...i do have one tree that's sort of in the way.
as far as equipment, what would be suggested ? Netgear RangeMax or Netgear Prosafe line ? Linksys ?
Thanks for all the help
Peter
As I said before, standard equipment should be fine with good high-gain antennas. For the outdoor antennas I suggest:
-or-
Any decent wireless access point (or router configured as an access point) and wireless client bridge with external antenna connectors can be used, but I'd personally stick with one vendor if you're buying new; e.g., Hawking HWBA54G Wireless-G Multi-Function AP/Bridge (which supports both modes).
On Thu, 10 Aug 2006 18:04:51 -0400, "Craig" wrote in :
