Engenius outdoor gear
Threaded View
I have searched through this group and suprisingly have not found a lot of
discussion about these products. Just about all of the posts dealt with the
PCMCIA or USB gear, NOT the outdoor AP's.
The reason I ask is because the company I work for will possibly be setting
up as a distributor and I was just looking for some input.
TIA,
DanS
Re: Engenius outdoor gear
On Wed, 21 Jun 2006 07:22:51 -0500, DanS
I believe the Engenius gear is rebadged SENAO
<http://www.senao-me.com/ .
Best regards,   FAQ for Wireless Internet: <http://Wireless.wikia.com
John Navas      FAQ for Wi-Fi:  <http://wireless.wikia.com/wiki/Wi-Fi
           Wi-Fi How To: <http://wireless.wikia.com/wiki/Wi-Fi_How_To
Fixes to Wi-Fi Problems:  <http://wireless.wikia.com/wiki/Wi-Fi_Fixes
Danger, Danger, Will Robinson...
Check out the threads on marine wifi and antennas.  Or buy one first
and see if you can make it work like you want (or, much more
appropriately, like your *customers* will want).
L8R
Skip, so far, burned and invested of hundreds of hours without
solution/working product
PS I can probably sell you a couple of these cheap - though maybe not
as cheap as distributor pricing - if the Discovercard dispute doesn't
resolve in my favor (which I expect it will)   See also
http://www.wlansolution.com/ProductDetails.asp?ProductCode=2611+CB3+PLUS+OD
fOn 23 Jun 2006 11:54:18 -0700, "Skip - Working on the boat"
Actually just:
   Danger, Will Robinson!
Don't forget the frantic arm-waving.
Hi, again :{))
I considered adding that definition, but given how clueless I am, I
feared it would just add to the image :{))
L8R
Skip
Hi, again, Dan,
Discovercard has declined to get involved; I now have available one of
these
(http://www.wlansolution.com/ProductDetails.asp?ProductCode=2611+CB3+PLUS+OD ),
with the die cast weatherproof housing and mounting hardware,
110VAC/12VDC power supply, N-mount lightning suppressor, pigtail from
the card to said lightning suppressor, and 8.5dBi N-mount omni
Hyperlink antenna, as well as another unit
(http://www.wlansolution.com/ProductDetails.asp?ProductCode=2611+CB3+PLUS+MD )
with the same power supply, and pigtail to a 5.5dBi rubber duck.
These are intended for joint use in the same housing, connected with
the (included) crossover cable.  However, either can be configured as
AP or Bridge.  They have been flashed with the most current firmware
and are both 200mw (23dBm) units.
It would probably be a good thing for your company to acquire these to
ascertain the appropriate level of enthusiasm for a distributorship.
I can make you an attractive package deal.
Let me know...
L8R
Skip
Morgan 461 #2
SV Flying Pig   KI4MPC
http://tinyurl.com/p7rb4 - NOTE:new URL! The vessel as Tehamana, as we
bought her
"Believe me, my young friend, there is *nothing*-absolutely
nothing-half so much worth doing as simply messing,
messing-about-in-boats; messing about in boats-or *with* boats.
In or out of 'em, it doesn't matter.  Nothing seems really to matter,
that's the charm of it.
Whether you get away, or whether you don't; whether you arrive at your
destination or whether you reach somewhere else, or whether you never
get anywhere at all, you're always busy, and you never do anything in
particular; and when you've done it there's always something else to
do, and you can do it if you like, but you'd much better not."
PS...
Both of these units have contained within them
http://www.wlansolution.com/ProductDetails.asp?ProductCode=2511CD+PLUS+EXT2 ,
the pcmcia card which can be used independently of power supplies or
external antennas (though they have antenna connection points if you
want to enhance the reception....
Site Timeline
