Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by ted on August 21, 2008, 6:33 am
Please log in for more thread options Hi I'd like ask about encoding after succesfull authorization 802.1x. I use wpa2 enterprise mixed mode + tkip, and in which way the payload is encoding? I don't type any static key for encoding, so maybe there is generate some random key for client and AP per session ? I'm not sure how it works corectly.. thx for any info regards Ted | ||||||||||||||||
Posted by Aaron Leonard on August 21, 2008, 3:48 pm
Please log in for more thread options ~ ~ Hi ~ ~ ~ I'd like ask about encoding after succesfull authorization 802.1x. ~ I use wpa2 enterprise mixed mode + tkip, and in which way the payload is ~ encoding? I don't type any static key for encoding, so maybe there is ~ generate some random key for client and AP per session ? I'm not sure ~ how it works corectly.. ~ ~ thx for any info ~ ~ regards ~ Ted Can you find what you're looking for at the Wi-Fi Alliance site http://www.wi-fi.org/knowledge_center/wpa/ ? For example, in http://www.wi-fi.org/files/wp_8_WPA%20Security_4-29-03.pdf ? Aaron | ||||||||||||||||
| Similar Threads | Posted |
| encoding after authorization 802.1x | August 21, 2008, 6:33 am |
| aaa authorization and aaa accounting with Cisco ACS and 1231 AP's | July 25, 2005, 5:29 pm |
| Understanding topology of wireless POS terminal card authorization | November 15, 2004, 3:51 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
