I live in a newer 1 story 2500sf home. The walls do not have foil backed insulation but we do have blown in insulation and metal studs within the house. I have a hardwired desktop and a new Dell XPS gen 2 laptop that has an Intel Pro Wireless 2915 adapter and a Netgear WGU 624 router. As long as the laptop is 4' away from the router I get great speeds, usually between 12 MBPS to sometimes 14MBps downloads. And am connected at 54 MBps. The problem occurs when I move the laptop to the family room or the living room which are between 30-40 feet away. The speeds drop precipitously. How can I find out what is causing the drop in speed and sometimes the entire connection? i.e. is it the router, adapter or house configuration? Or all three? I'm sure I could go out and purchase a new router and test it. And/or a new adapter but I was wondering if there were some way of testing this some other way. Moving the router to a different location is really not an option. Please advise. thank you. DotCom
- posted
18 years ago
