Any experience with this product anyone? I wanted to start a thread on this product and see if anyone else has any comments on the product or similiar problems as described below. All of my configuration and troubleshooting is done via telnet. I can give LOTs of more information if anyone is interested.
Issue #1) The first is that when I configure the DWL-3200AP with VLAN support, the AP reboots on random intervals. I have 16 in the school and they all reboot completely randomly and independently of one another when configured with multi-SSID support on VLANs. When I disable VLAN support, no reboots!
Issue #2) When modifying the transmit power level, the power level never actually get's reduced. Let me show: AP-Weightroom wlan1 -> get power TransmitPower: half (-3 dB) Current Transmit Output Power 22.0 dBm AP-Weightroom wlan1 -> set power min Transmit Power: Min AP-Weightroom wlan1 -> reboot : AP-Weightroom wlan1 -> get power TransmitPower: min Current Transmit Output Power 22.0 dBm
Regarding #1, here is my config script for what DOES cause a reboot and what does NOT:
DOES reboot APs: set ssidsuppress disable set multi-state enable set vlanstate enable set nativevlan 16 set ssid Borgia set vlantag 15 # (Also tried 16) set encryption disable set multi-ind-state enable 0 set multi-ssid 0 FacultyWLAN set multi-authentication open-system 0 set multi-cipher wep 0 set multi-keyentrymethod asciitext 0 set multi-vlantag 13 0 set multi-key 104 [blanked] 1 0 set multi-encryption enable 0 set multi-ind-state enable 1 set multi-ssid 1 StudentWLAN set multi-authentication open-system 1 set multi-cipher wep 1 set multi-keyentrymethod asciitext 1 set multi-vlantag 14 1 set multi-key 104 [blanked] 2 1 set multi-encryption enable 1 set multi-ind-state disable 2 set multi-ssid 2 C set multi-encryption disable 2
Does NOT reboot the APs: set vlan disable set vlanstate disable set multi-state disable set multi-ind-state disable 0 set multi-ssid 0 A set multi-encryption disable 0 set multi-ind-state disable 1 set multi-ssid 1 B set multi-encryption disable 1 set multi-ind-state disable 2 set multi-ssid 2 C set multi-encryption disable 2 set ssid FacultyWLAN set ssidsuppress disable set authentication open-system set cipher wep set encryption enable set keyentrymethod asciitext set key 1 104 [blanked] set key 1 default
