A specific question. Non wi fi but a router question. A router that was attached to a DSL line is to be used by a nube for remote access ( stupid nube at that. ) DSL broadband connection. New D-Link DI604 router about a month old . The router is unattended throughout the nightime for an extended period. I am unsure of the settings of the router. Most likely default settings. The newer versions of routers seem to have higher default security settings than the older versions . When the router goes into an unattended mode and then the internet connection is reactivated will the ip change ? The DSL connection is to be used for remote access monitoring program. My concern is that the ip will change , making the remote access inaccessible and that a ip tracking program should be used. Any help with an answer to this question ?
- posted
18 years ago
