The internet connection on my windows xp machine connected wirelessly to my netgear mr814 router drops off if the computer is left idle for a short amount of time, perhaps 20-30 mins and fails to re-establish itself. I must re-set the modem and router for it to re-establish itself.
Incidentally, i've discovered if i just run ping tests all day long say set the -n to 10 million or whatever, the connection stays on when am away from the computer, i guess the ping tests are keeping the router busy so it doesn't drop off, I'm not sure exactly what all of this means, but it is a minor annoyance.
Read some posts about adjusting the 'idle timeout' from default 5 to 0 mins in the router settings, but tried this and it hasn't fixed it, have contacted netgear but have not heard back from them yet on it. Router is using up to date firmware.
The wired machine can run all day on the wired router and be left idle for any length of time and still stay connected, it's only the one connected wirelessly this happens to. If i sit and work at the wireless machine constantly the connection seems ok for as long as I'm working but if i stand up for a while and come back it has often lost the connection, it is not due to signal strength of the router, that is fine.
