The output of wpa_supplicant ...... -d indicates that the driver for the wireless card doesn't support WPA while dmesg | grep wlan0 indicates that it does. How can this be? I have the same wireless device on another PC that works fine with this driver.
Trouble computer: MSI Athlon 64 running 32 bit version of Mandriva 2006, custom kernel 2.6.16.16, WUSB54G version 4, driver rt2500usb
Good computer: MSI Athlon running 32 bit version of Mandriva 2007, stock kernel, WUSB54G version 4, driver rt2500usb
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf' Reading configuration file '/etc/wpa_supplicant.conf' ctrl_interface='/var/run/wpa_supplicant' ctrl_interface_group=10 (from group name 'wheel') Priority group 0 id=0 ssid='$$$$' Initializing interface (2) 'wlan0' EAPOL: SUPP_PAE entering state DISCONNECTED EAPOL: KEY_RX entering state NO_KEY_RECEIVE EAPOL: SUPP_BE entering state INITIALIZE EAP: EAP entering state DISABLED EAPOL: External notification - portEnabled=0 EAPOL: External notification - portValid=0 SIOCGIWRANGE: WE(compiled)=19 WE(source)=18 enc_capa=0xf capabilities: key_mgmt 0xf enc 0xf Own MAC address: 00:18:39:04:43:4d Driver does not support WPA. wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0 wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0 wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0 wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0 Setting scan request: 0 sec 100000 usec Added interface wlan0 Wireless event: cmd=0x8b06 len=8 RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added State: DISCONNECTED -> SCANNING Starting AP scan (specific SSID) Scan SSID - hexdump_ascii(len=6): 67 6f 41 77 61 79 $$$$ Scan timeout - try to get results Received 257 bytes of scan results (1 BSSes) Scan results: 1 Selecting BSS from priority group 0
0: 00:12:17:e2:8d:05 ssid='$$$$' wpa_ie_len=26 rsn_ie_len=0 caps=0x11 selected based on WPA IE Trying to associate with 00:12:17:e2:8d:05 (SSID='$$$$' freq=2462 MHz) Cancelling scan requestndiswrapper version 1.21 loaded (preempt=no,smp=no) ndiswrapper: driver rt2500usb (Linksys,10/17/2005, 2.01.00.0000) loaded wlan0: ndiswrapper ethernet device 00:18:39:04:43:4d using driver rt2500usb,
13B1:000D.F.conf usbcore: registered new driver ndiswrapperwlan0: vendor: 'Linksys Wireless-G USB Network A' wlan0: ndiswrapper ethernet device 00:18:39:04:43:4d using driver rt2500usb,
13B1:000D.F.conf wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK _______________________________________________ HostAP mailing list snipped-for-privacy@shmoo.com
