Hello
I am in the process of setting up a wireless access point for a small company. It will be used as another means for staff to connect to the Internet and gain access to shared network resources. At present, I can gain Internet Access via any wireless connection...but cannot browse the network.
I've tried various configurations, but at present, this is the configuration that is being used while we troubleshoot.
Static IP assigned to router (e.g. 10.200.x.x) Subnet mask, DNS etc. all match those within the domain.
DHCP is enabled for the network portion of the configuration. Router IP for network access is default (192.168.1.1)
Any connecting workstation is able to access the internet and obtain a
192.168.x.x address.The problem appears to be the Checkpoint firewall. We believe that we have unrestricted access in out for HTTP traffic, but LAN traffic (RPC etc.) is being blocked.
If anyone has any suggestions for a configuration (create a subnet for the wireless network? set up specific rules in the firewall) I'd appreciate the input.
Thanks!
