I am trying to crack the WEP of the local firestations router.. The SSID is "default". This, I think, is a D-link router..but not sure which one. I figured that, if the local fireman could not be bothered to change the SSID then, maybe he chose only to use some WEP examples that are displayed in the router, wireless set-up page.. If anyone out there with a D-link could give me any ideas what he could be using as a WEP code then I would be most grateful...thanks.
- posted
17 years ago
